Normal Topic shapenode label (Read 6092 times)
tmtton
shapenode label
May 28th, 2008 at 4:02am
I need to have a shapeNode label that must reside inside the box (which could be a circle, a rectangle, or a diamond)  and is separate from the shapeNode text.
I attach the labelNode, laying it on top of the shapeNode. This almost does what I want. Two pending issues:
1) cut/copy/paste doesn't work on the labelNode
2) when the shapeNode's text is long, it fills up the whole box and overlaps with the labelNode's text appearing at the top of the shapeNode. how to prevent the "shapeNode label area" from being written to?
Thanks in advance for any suggestions.
--- code snippet ---
ShapeNode shapeNode = new ShapeNode(diagram);
// set shapeNode properties ...
ShapeNode labelNode = new ShapeNode(diagram);
labelNode.setText("Node Label X");
labelNode.setLocked(true);
labelNode.setTransparent(true);
// set other labelNode properties ...
labelNode.attachTo(shapeNode, attachToNode.TopCenter);
diagram.add(shapeNode);
diagram.add(labelNode);
Re: shapenode label
Reply #1 - May 28th, 2008 at 9:10am
1. Set the "groups" argument to true when calling the CopyToClipboard and CutToClipboard methods.
2. You could use a custom Shape definition whose text area excludes the region where the labelNode would be located.
tmtton
Re: shapenode label
Reply #2 - May 29th, 2008 at 1:38am
Thank you. The group=true setting works for copy and cut to clipboard function. However, when a user uses the Delete key to remove the selected shapeNode, the associated labelNode is not deleted from the diagram.
Re: shapenode label
Reply #3 - May 29th, 2008 at 7:36am
After attaching the labelNode, call shapeNode.getSubordinateGroup().setAutoDeleteItems(true).
tmtton
Re: shapenode label
Reply #4 - May 30th, 2008 at 12:13pm
I have this scenario.
- create a shapeNode. create a labelNode. attach the labelNode to the shapeNode.
- execute an undo
- the labelNode is detached from the group (labelNode is removed and the shapeNode now has no label)
- execute an undo again
- the shapeNode is then removed
How do we prevent the detachment? We need the label + shape to come and go together.
Re: shapenode label
Reply #5 - May 30th, 2008 at 2:43pm
Call Diagram.getUndoManager().startComposite() before creating and attaching the nodes, and CompositeCmd.execute() after that.
