Normal Topic Tag loads as Null (Read 1423 times)
josephsolaris
Tag loads as Null
Jun 4th, 2008 at 6:48pm
We are using FlowChart.NET 5.0.1, and in our program we use tags that are objects, not strings; our program uses the diagram.SaveToString() method to save the tags.  When the program tries to load a saved project, we load the tags using the diagram.LoadFromString() method, but the tags come back null.  Any ideas of how to fix this or why it is happening would be appreciated.
Re: Tag loads as Null
Reply #1 - Jun 4th, 2008 at 7:29pm
Mark the class of your tag objects as [Serializable]. Also implement the ISerializable interface if you plan to change that class in the future - that will let you realize some versioning logic for backward compatibility.
josephsolaris
Reply #2 - Jun 4th, 2008 at 8:02pm
Thanks!! Works fine now!
