Normal Topic Java.lang.NullPointerException (Read 5779 times)
dhoult
Jun 5th, 2008 at 2:07pm
Running in Applet mode. This exception happens about 50% of the time while loading the page and page does not finish loading. The other 50% it works fine and great.
Any ideas?
dhoult
Re: Java.lang.NullPointerException
Reply #1 - Jun 5th, 2008 at 2:09pm
Full text from Java Console:
java.lang.NullPointerException
at sun.plugin.AppletViewer.loadJarFiles(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Reply #2 - Jun 5th, 2008 at 2:24pm
It doesn't seem the to reach the Netdiagram's applet's code at all. With what browser and Java runtime version are you getting the exception?
dhoult
Reply #3 - Jun 5th, 2008 at 2:30pm
IE7
Java (build 1.6.0_05-b13)
So this could be a problem with code before we get to the applet? as in OUR code? we don't make mistakes Wink
whatever the issue, I just want to track it down so if i can eliminate your applet from the possible sources that's a step forward.
Reply #4 - Jun 5th, 2008 at 4:03pm
Never said it's your code, the exception log shows the culprit is sun.plugin.AppletViewer Wink Are there any other applets on the page apart from the Flowchart, e.g. the Overview, ShapelistBox, or some third-party applets? Have you set the JarLocation property?
dhoult
Reply #5 - Jun 5th, 2008 at 4:06pm
we have this defined first:
<ndiag:flowchart id="palette" JarLocation="/Content/JDiagram.jar" runat="server" style="left: 0pt;" BorderColor="#e8eef7" BorderStyle="None" BoxClickedScript="palette_BoxClicked" AntiAlias="AntiAlias" BorderWidth="0" AutoActivateApplet="True"></ndiag:flowchart>
then further down the page we have this:
<ndiag:flowchart id="canvas" JarLocation="/Content/JDiagram.jar" ArrowCreatedScript="canvas_ArrowCreated" DocClickedScript="canvas_DocClicked" runat="server" style="position: absolute; top: 50px;left: 300px" BoxDblClickedScript="canvas_BoxClicked" AntiAlias="AntiAlias" AutoActivateApplet="True"></ndiag:flowchart>
Reply #6 - Jun 5th, 2008 at 4:14pm
Actually AutoActivateApplet is not required anymore, since Microsoft removed the "click to activate" feature from IE with a recent Widows Update. Try how that will work with AutoActivateApplet set to false. It might help, because the auto-activate feature leads to injecting the applets into the DOM via JavaScript, which could get the applet plugin into trouble.
dhoult
Reply #7 - Jun 5th, 2008 at 4:16pm
ok, I'll give that a whirl and let you know.
dhoult
Reply #8 - Jul 27th, 2008 at 12:53pm
sorry, forget to let you know.
That was the issue Smiley
Thanks.
