Normal Topic Long build time (Read 2111 times)
MagnusSpeychal
Long build time
Jun 9th, 2008 at 11:19am
Hi
We are using FlowChartX in a MS Visual Studio project which builds to a dll. When building a debug version of the project everything works fine but when we try to build a release version of the project it takes a very long time to complete the build.
Do have any ideas what might cause this long build time?
Best regards,
Magnus
Re: Long build time
Reply #1 - Jun 9th, 2008 at 12:02pm
I suppose the build is slower because of the optimizations done by the C++ compiler in release configuration. You can verify this by disabling the optimizations from the project's compiler options window.
Re: Long build time
Reply #2 - Jun 9th, 2008 at 12:08pm
Additionally, check if the "precompiled headers" option is enabled for your release configuration.
