Normal Topic Zoomfactor (Read 5339 times)
dku
Zoomfactor
Jun 16th, 2008 at 7:18am
I've a diagram inside a user control that can resize. When resizing, I set the Bounds of the diagram. My method Apply layout is computing the spaces between layers (layered layout) but could take some time.
So, to have a smooth resize, I've try to implement a zoomed diagram and after some delay, the layout is performed.
But when I'm setting the ZoomFactor, the bounds are changed ?
private void UserControl_SizeChanged(object sender, SizeChangedEventArgs e) {
		double l_OldWidth = myGraphicalExplorerDiagram.Bounds.Width;
		myGraphicalExplorerDiagram.Bounds = new Rect(0, 0, e.NewSize.Width, e.NewSize.Height);
		myGraphicalExplorerDiagram.ZoomFactor *= (e.NewSize.Width / l_OldWidth);
		m_ResizeDispatcherTimer.Stop();
		m_ResizeDispatcherTimer.Start();
	  void ResizeDispatcherTimerHandler(object sender, EventArgs e) {
		myGraphicalExplorerDiagram.ZoomFactor = 100;
		this.ApplyLayout();
Thanks for any hint.
Bye
Didier
Re: Zoomfactor
Reply #1 - Jun 16th, 2008 at 7:48am
Setting ZoomFactor will change the size of the diagram control to Bounds * ZoomFactor / 100, but should not change the Bounds value, if that's what you mean?
dku
Re: Zoomfactor
Reply #2 - Jun 16th, 2008 at 8:51am
Visually I see the diagram changing its size, it is probably what you say, the diagram control bounds are changed.
The property Bounds is not setting the diagram control size ?
Any idea on how I can achieve my goal ? (that the diagram is resizing with the user control containing it by redrawing only - relayout will occur later through dispatcher)
By the way, it could be fine to have a zoom factor per axis (x - y).
Didier
Re: Zoomfactor
Reply #3 - Jun 16th, 2008 at 9:30am
The final size of the control depends on three properties - Bounds, MeasureUnit, ZoomFactor. Bounds is scaled by the MeasureUnit to WPF point ratio to find the non-zoomed size, and then by ZoomFactor / 100 to find the zoomed size. I could not understand what exactly are you trying to achieve?
dku
Re: Zoomfactor
Reply #4 - Jun 16th, 2008 at 11:04am
I've a diagram control in a resizable area (grid, with splitter).
I'm using the layered layout to arrange my diagram, computing the layer distance according to the width available.
So, I want the following behavior :
- Once diagram resized, I arrange the elements using layered layout with new computed layout distance
- WHEN resizing, I cannot arrange the elements, it takes too longer. So I've thought using the zoom factor to adapt the diagram to the new size. I want to follow the resize as a better feedback experience to the user.
Didier
Re: Zoomfactor
Reply #5 - Jun 16th, 2008 at 1:41pm
There is a ZoomTiFit method in our Windows Forms control, and it should help you do what you need. We'll port it to WPF later this week.
Re: Zoomfactor
Reply #6 - Jun 18th, 2008 at 1:35pm
This version adds the ZoomToFit and ZoomToRect methods:
https://mindfusion.eu/_beta/wpfdiag101pre.zip
The Diagram must be placed inside a ScrollViewer for them to work correctly.
