Normal Topic Strange behaviour when using LINQ (Read 1999 times)
pelion
Jun 20th, 2008 at 12:13am
Hi Stoyo,
I realise that this problem may be out of your area of control, but I thought I'd mention it, in case you can provide some insight, or have seen it before.
I am trying to get a sorted list of the Boxes on a chart, first by their X, then Y, coordinates, for example
{0,1} {0,2} {0,3} {1,0} {1,3} etc
I decided to use LINQ for Objects for its simplicity.
First to get a List that LINQ could work with I added a method (performance-wise, not an ideal start. If I can get it working, I'll probably eventually override the GetEnumerator() method and add an orderBy Extension):
private static List<Box> GetBoxesAsList(FlowChart chart)
            List<Box> boxes = new List<Box>();
            foreach (Box box in chart.Boxes)
                boxes.Add(box);
            return boxes;
This returns a List of Type Box, and in the debugger their positions are apparently in a random (in fact order of added) order.
I then added an extension method to the chart
public static List<Box> GetBoxesByPosition(this FlowChart chart, Orientation orientation)
if (orientation == Orientation.Auto)
                orientation = Orientation.Horizontal;
            var result = from b in chart.GetBoxesAsList()
                         orderby orientation == Orientation.Horizontal ? b.BoundingRect.X : b.BoundingRect.Y,
                                 orientation == Orientation.Horizontal ? b.BoundingRect.Y : b.BoundingRect.X
                         select b;
            return result.ToList<Box>();
but the outcome always gave me a list of Boxes at position (5.0, 5.0) (they were different boxes, just with their positions reset)
To see if I was mucking something up with my orierntation condition, or the double order, I first tried
orderby b.BoundingRect.X, b.BoundingRect.Y
and
but still every box was getting its position reset to (5.0, 5.0)
I thought I'd try simple lambda (I can't believe I used the term 'simple' and the term 'lambda' next to each other)
return GetBoxesAsList(chart).OrderBy(p => p.BoundingRect.X).ThenBy(p => p.BoundingRect.Y).ToList();
but still 5,5
I even tried specifying p.BoundingRect.Location.X and Y, but by then I was getting the strong impression that I was just doing the same thing over and over in a different way.
I am wondering if the Location Coordinates 5.0, 5.0 give any hints to what might be going on.
I am now facing the realisation that I am going to have to code up my own sorting algorithm Sad dammit
Thanks in advance for any advice you may give
JC
pelion
Re: Strange behaviour when using LINQ
Reply #1 - Jun 20th, 2008 at 12:33am
I've tested the lambda code with
class objWithPosition
	  public objWithPosition(RectangleF f)
		BoundingRect = f;
	  public RectangleF BoundingRect { get; set; }
		//Test bug
		List<objWithPosition> test = new List<objWithPosition>();
		test.Add(new objWithPosition(new RectangleF(1,2,3,4)));
		test.Add(new objWithPosition(new RectangleF(3,4,2,1)));
		test.Add(new objWithPosition(new RectangleF(6,3,6,9)));
		test.Add(new objWithPosition(new RectangleF(4,9,4,2)));
		List<objWithPosition> sorted = test.OrderBy(p => p.BoundingRect.Location.X).ThenBy(p => p.BoundingRect.Location.Y).ToList();
and it doesn't reset the internal BoundingRect.
It all seems very quantum, affecting something simply by observing it  Wink
pelion
Reply #2 - Jun 20th, 2008 at 1:08am
The plot thickens, it appears to be something about hashing boxes
In order to get around this for the moment, I returned from my LINQ Query a List of Box Tags (all unique), then compared them to a dictionary of boxes by tags.
foreach (object tag in tags)
    boxToAdd = _boxByTag[tag];//get box first to test its position
    boxes.Add(_boxByTag[tag]);
In the dictionary (or hashtable) the position of the box is correct (as a watch or in the immediate window), but when I retreive it (into a variable like boxToAdd), it loses its position (5.0, 5.0).
Are you overriding the GetHashKey function for the chart Nodes?
BTW, we are still, prehistorically, on v4.2.2, but don't have the luxury of time to upgrade just yet.
[edit]
chart.FindBox(tag); is also resetting my positions
Reply #3 - Jun 20th, 2008 at 7:40am
To my shame, I know nothing of LINQ yet 8) You could try this more traditional method:
class NodeComparer : IComparer<DiagramNode>
	public int Compare(DiagramNode n1, DiagramNode n2)
		if (n1.Bounds.X < n2.Bounds.X) return -1;
		if (n1.Bounds.X > n2.Bounds.X) return 1;
		if (n1.Bounds.Y < n2.Bounds.Y) return -1;
		if (n1.Bounds.Y > n2.Bounds.Y) return 1;
		return 0;
List<DiagramNode> nodes = GetNodesAsList(diagram);
nodes.Sort(new NodeComparer());
I can't find GetHashKey overridden anywhere in the Flowchart.NET code, but I'll get our developer to investigate.
pelion
Reply #4 - Jun 20th, 2008 at 10:21am
No worries Stoyo, thanks for that.
From further investigation, the problem only seems to arise when the box size is (1,1), not sure why (I'm using the tree layout for positioning purposes only at this stage, them applying them to a grid).
Thanks for the 'trad' code.
