Normal Topic HtmlBuilder createImageMap (Read 1751 times)
tmtton
Jun 20th, 2008 at 2:31pm
I use JDiagram 2. The diagram only has DiagramNode (ShapeNode specifically) and DiagramLink. I can export my diagram to an image without a problem.
When I use HtmlBuilder to create a HTML Image Map, all I get is <MAP NAME="fcImgMap"></MAP>. I expected to see map HTML code with multiple AREA elements. What am I missing?
HtmlBuilder htmlBuilder = new HtmlBuilder(diagram);
String createImageMapString = htmlBuilder.createImageMap("fcImgMap");
Also, is there a sample showing how the ExpandButtonHyperlink is used? Thanks,
Re: HtmlBuilder createImageMap
Reply #1 - Jun 20th, 2008 at 4:57pm
There are areas generated only for items whose Hyperlink property is set. Have you assigned a hyperlink to any item?
