Normal Topic store tags in XML (Read 1922 times)
tmtton
store tags in XML
Jun 27th, 2008 at 5:03pm
I use JDiagram 2. I need to store all serialized tags associated with nodes in the diagram. I can store/recall tags with saveTo/loadFrom function. But saveToXml by itself does not store the tags. How to add these tag data to the XML file?
Re: store tags in XML
Reply #1 - Jun 29th, 2008 at 6:20am
You must implement the serializeTag and deserializeTag methods of DiagramListener. The methods receive a SerializeTagEvent argument. Its getTagElement() method returns an XML Element object where you can write or read your tag data through the DOM API. You must also call e.setHandled(true) before returning from the serialize/deserialize methods.
