Normal Topic Can table row heirarchy go deeper than one level? (Read 1824 times)
brianh
Jul 1st, 2008 at 4:11pm
I need to display data in each diagram node as a tree view, but the TableNode class only seems to allow one level of expansion.  Is it possible to add more, or at least fake it somehow?
I know I could use the ControlNode class to host a tree view but this has it's limitations, so I would like to use the table view if possible.
Thanks.
Re: Can table row heirarchy go deeper than one lev
Reply #1 - Jul 1st, 2008 at 6:08pm
Only one level of expansion is possible at this time. I suppose you can fake a deeper hierarchy by adding more columns and displaying the data for an Nth-level tree item in the Nth cell of the respective row. Collapsing the rows could be implemented by seting their Height to 0.
Another possibility is to create a custom node type that renders the tree data in its Draw implementation.
brianh
Reply #2 - Jul 2nd, 2008 at 8:04am
Thanks Stoyan,
I think I'll try and fake it for now (although I think this would be a useful featiure for you to add in future), but is there a way to access the expansion icons (+/-) that are used in the table, or do I just have to copy them and make my own icons?
Brian
Reply #3 - Jul 2nd, 2008 at 9:02am
Hi Brian,
They aren't really icons, but you can draw them by calling the InternalUtils.DrawExpandButton method. You could do that from the DrawCell event handler if you enable TableNode.CellCustomDraw.
