Normal Topic saveToXml .NET vs JAVA (Read 2892 times)
tmtton
Jul 2nd, 2008 at 1:52pm
Do the FlowChart.NET and JDiagram share the same XML schema? We like to know if a XML document saved with the .NET version can be read back by the JAVA's loadFromXml method, and vice versa.
Re: saveToXml .NET vs JAVA
Reply #1 - Jul 2nd, 2008 at 1:58pm
Yes, they do - that's how our ASP.NET diagramming control transfers data between the applet and the server.
tmtton
Reply #2 - Jul 16th, 2008 at 3:17pm
We need to parse the XML document file that is generated from the FlowChart.NET or JDiagram API. Is there a DTD or XML Schema for the generated XML file?
Reply #3 - Jul 16th, 2008 at 6:00pm
There isn't any formal schema. Instead of parsing the XML files, you might create an off-screen Diagram object, call loadFromXml, and then access the diagram items and check their properties through the JDiagram / Flowchart.NET API.
