Normal Topic RoutingOptions.GridSize (Read 7198 times)
CedricL
Jul 2nd, 2008 at 2:43pm
We're currently moving our ASP.Net application from NetDiagram 1.1 to NetDiagram 2.0
A problem occurs with 1.1 option "RoutingOptions.GridSize". It seems it does not exist under 2.0.
How to replace it ?
(Same problem with "RoutingOptions.LengthCost")
Thanks.
Re: RoutingOptions.GridSize
Reply #1 - Jul 2nd, 2008 at 3:33pm
RoutingOptions is a member of the Digram class now. Try this:
Diagram d = diagramView.Diagram;
d.RoutingOptions.GridSize = 5;
d.RoutingOptions.LengthCost = 1;
d.RouteAllLinks();
CedricL
Reply #2 - Jul 2nd, 2008 at 3:37pm
Well, that was what I tried to do, but I got the following error:
'MindFusion.Diagramming.RoutingOptions' does not contain a definition for 'GridSize' and no extension method 'GridSize' accepting a first argument of type 'MindFusion.Diagramming.RoutingOptions' could be found (are you missing a using directive or an assembly reference?)
Reply #3 - Jul 2nd, 2008 at 3:39pm
Could you copy your code here?
« Last Edit: Jul 2nd, 2008 at 6:00pm by Stoyo »
CedricL
Reply #4 - Jul 3rd, 2008 at 6:34am
Here is the part we use in our Page.aspx.cs:
FlowChart.Diagram.RoutingOptions.GridSize = 70.0f;
FlowChart is the DiagramView component ID in our Page.aspx
Reply #5 - Jul 3rd, 2008 at 7:10am
Right, I've tried this with the released version now, and apparently the obfuscating tool we are using has decided to obfuscate some RoutingOptions property names even if they are public ??? (You can see them listed in the Intellisense popup starting with "x"). We will investigate why that happens and send you a fixed version later today.
CedricL
Reply #6 - Jul 3rd, 2008 at 7:12am
Yes, I noticed these "x" methods. I'm waiting for your fix.
Reply #7 - Jul 3rd, 2008 at 11:04am
Open the Private Messages page from the link at the top of the page, you will find the download link there.
CedricL
Reply #8 - Jul 3rd, 2008 at 12:42pm
Thanks. Now our project compiles without any error.
