Normal Topic expandbuttonclicked in netdiagram 2.0 (Read 1737 times)
lue
I love NetDiagram!
Jul 8th, 2008 at 4:20am
We would like use the expandbuttonclicked event (+/-) to save the id (tag) of a shape node (in the imagemap mode) in a session variable, but we get alway errors:
Compiler Error Message: BC30590: Event 'ExpandButtonClicked' cannot be found.
Source Error:
Sub diagramView_ExpandButtonClicked(ByVal sender As Object, ByVal e As NodeEventArgs) Handles diagramView.ExpandButtonClicked
If Not e.Node.Tag Is Nothing Then Session("Toggle") = e.Node.Tag
End Sub
the html code of the page contains:
<form id="Form1" method="post" runat="server">
  <p align="left">
  <ndiag:DiagramView id="diagramView" runat="server" width="1800px" height="1200px" clientsidemode="ImageMap" OnExpandButtonClicked="diagramView_ExpandButtonClicked">
  <diagram backbrush="s:#FFFFFFFF" /></ndiag:DiagramView>
  </p>
Whats wrong?
Is there another possibility to get the node.tag on the server side?
We use vb.net (asp.net 2.0)
thanks and regards
chris
Re: expandbuttonclicked in netdiagram 2.0
Reply #1 - Jul 8th, 2008 at 5:47am
The ExpandButtonClicked event from Flowchart.NET in not available in NetDiagram Imagemap mode yet. You could handle TreeExpanded and TreeCollapsed instead, and you could undo the expand/collapse operation by calling e.Node.Collapse or e.Node.Expand from the handler.
