Normal Topic problems with clientside events in javaapplet mode (Read 2811 times)
lue
I love NetDiagram!
Jul 14th, 2008 at 6:36am
We use netdiagram 2.01 with vb.net.
But in Java Applet Mode we cannot  use client side events.
We would like make with a click on a node an event to open a popup window or make other events.
in the html body of page:
    <ndiag:diagramview id="diagramView" style="LEFT: 0px; WIDTH: 540px; POSITION: absolute; TOP: 100px; HEIGHT: 480px" runat="server" clientsidemode="JavaApplet" onnodeclicked="diagramView_NodeClicked" />
in the vb.net page_load:
Sub diagramView_NodeClicked(ByVal sender As Object, ByVal e As NodeEventArgs) Handles diagramView.NodeClicked
Session("Message") += "NC "
End Sub
The diagram is ok, but no reactions on click the node ...
whats wrong?
thanks & regards
chris
Re: problems with clientside events in javaapplet
Reply #1 - Jul 14th, 2008 at 7:52am
You will have to code the event handler in JavaScript, and assign its name to the NodeClickedScript property. For example see the OrgBrowser and NetworkChart sample projects.
lue
I love NetDiagram!
Reply #2 - Jul 14th, 2008 at 11:04am
Thanks Stoyan!
Is there any possibility in the java applet mode to transfer data from client side events to the server side f.e. to save this data in session variables?
regards chris
Reply #3 - Jul 14th, 2008 at 11:37am
I suppose you could add some Hidden fields to an UpdatePanel and post back just the panel when a client-side event is raised. You might also try passing the session id to a web service method, and let the method set the session variables.
lue
I love NetDiagram!
Reply #4 - Jul 14th, 2008 at 12:02pm
Thanks Stoyan, that helps!
Another question: Are they any client side events for drag & drop related events. We have not found such events ...
best regards chris
