Normal Topic Performance Problems (Read 3339 times)
slederer
Jul 17th, 2008 at 9:38am
I've tested the resource view component in one of your test application. Therefore i added 100 resources to the component with 25 appointments. But this was not possible because my Visual Studio 2005 brought a deadlock exception or the application do not react anyway.
This is my code for adding the appointments:
foreach (Resource r in calendar.Schedule.Resources){
                for (k = 0; k < 5; k++)
                    for (i = 0; i < 5; i++)
                        task = new Appointment();
                        task.HeaderText = "Task";
                        task.DescriptionText = "This is a task.";
                        task.StartTime = (new DateTime(2007, 7, 17 + k, i, 0, 0, 0));
                        task.EndTime = (new DateTime(2007, 7, 17 + k, i, 30, 0, 0));
                        task.Resources.Add(r);
                        calendar.Schedule.Items.Add(task);
                        j++;
Greetings
Stefan lederer
Re: Performance Problems
Reply #1 - Jul 17th, 2008 at 10:55am
If you have added 100 resources to the schedule, it looks to me that the code you posted will create 2500 appointments instead of only 25. I have tried it in a sample application and the appointments were created successfully in a matter of seconds. However, I was using a Timetable view where many of the appointments are invisible due to the lack of space to display them. If you are using another view, it might take longer to display all of the appointments.
Anyway, you can use the following technique to speed up the appointment creation. Just keep in mind that your code as it is, will create appointments whose count is 25 times the number of resources:
calendar.BeginInit();
// Put all of the initialization code in here
calendar.EndInit();
slederer
Reply #2 - Jul 18th, 2008 at 7:28am
Thank you for your reply! It works!
slederer
Reply #3 - Jul 28th, 2008 at 1:37pm
I've another problem with my test application: when i drag an appointment through the calendar (fullscreen, 100 resources with 25 appointments per ressource), my CPU load goes up to 50% (1,8 GHz Dual Core CPU). It's also very slow in this case. Is this normal is this case? Have i done something wrong in my implementation?
Reply #4 - Jul 28th, 2008 at 2:47pm
Moving an item across a view forces a layout pass every time the item position is changed. In view with that many resources and appointments it is normal to experience slow-downs. Here are some tips that can improve performance:
1. Turn item shadows off or at least make the shadows solid. Fading shadows render very slow.
2. Enable rendering optimization through the Calendar.EnableOptimization property.
3. Set the Calendar.ItemModificationStyle property to anything other than InPlace. This will prevent the view from laying out all items every time a dragged item is moved. The items will be laid out once the dragged item is dropped.
