Normal Topic Prevent auto arrange of container child nodes (Read 4053 times)
Hicky
Jul 18th, 2008 at 5:29am
I created a container node (foldable) with tree child shape nodes (on different positions) inside. When I fold the container node and move this object to a new position and unfold the container, the child shape nodes were rearranged and have new positions inside the container node.
I have a simple question: How can I prevent the auto rearrange of container child nodes after moving the folded container node on a diagram?
I'm using FlowChart.NET 5.0.3 and VisualStudio 2005 (VB).
Re: Prevent auto arrange of container child nodes
Reply #1 - Jul 18th, 2008 at 9:39am
Perhaps you have some event handler that re-arranges the nodes?
Hicky
Reply #2 - Jul 18th, 2008 at 10:30am
I could create a rearrange function after moving a folded node, but is there no way in FlowChart.NET to prevent this auto rearrange from the child nodes of a container object?
Reply #3 - Jul 18th, 2008 at 10:35am
What I meant is that Flowchart.NET should not move the contained nodes on its own whim; could you check if by chance some event handler of yours does that?
Hicky
Reply #4 - Jul 21st, 2008 at 5:13am
I haven't some event handlers active which rearrange this nodes! The container node automatically rearrange the shape nodes inside after the folded container were moved over the diagram.
Reply #5 - Jul 21st, 2008 at 8:37am
Could you call SaveToXml and email the file to support@mindfusion.eu?
Hicky
Reply #6 - Jul 21st, 2008 at 9:08am
Yes, I have sent you an email with attached xml export of my diagram. Thank you for your support.
Reply #7 - Jul 21st, 2008 at 2:37pm
This happens because of the KeepInsideParent constraint. Apparently the control applies it too strictly - even when a container is folded, so the child nodes are moved to fit the smaller container size. Until our developers fix that, turn the constraint off when a container is folded and enable it again when a container is unfolded.
Hicky
Reply #8 - Jul 22nd, 2008 at 8:49am
I tried this workaround in my solution and now the positions of the child nodes are correct. Thank you for your support.
