Normal Topic Selection - change appearance (Read 4716 times)
dku
Jul 25th, 2008 at 2:12pm
When I select an diagram item, the different handles are showing the selection. Is that possible to override this appearance ?
I want to show a simple rect around the item ?
Didier
Re: Selection - change appearance
Reply #1 - Jul 25th, 2008 at 2:33pm
You could set DiagramNode.HandlesStyle = DashFrame or HatchFrame.
dku
Reply #2 - Aug 4th, 2008 at 11:51am
Yes, it is what I want.
What about the color ? Smiley
I've tried ActiveItemHandlesBrush and SelectedItemHandlesBrush on the diagram object.
Didier
Online
Reply #3 - Aug 4th, 2008 at 1:53pm
So there are hardcoded black on white colors used for HatchFrame, and the property values are ignored. Whereas DashFrame shows the colors specified with the properties. We will fix this and send you the new version tomorrow.
g.
Online
Reply #4 - Aug 6th, 2008 at 8:51am
I've just sent you a private message containing the download link.
dku
Reply #5 - Aug 11th, 2008 at 11:13am
Thanks a lot.
As far as we purchased WpfDiagram with Source Code, we build our dll form the sources (to allow debugging if necessary).
Do you have any release plan/roadmap for the next release ?
Bye
Didier
PS : I can use the dll you give to me for development, but I cannot release my product sofar it is not an official WpfDiagram release.
Online
Reply #6 - Aug 11th, 2008 at 12:18pm
You can fix this in InternalUtils.cs. Find the DrawSelHandles method there, and in the if (st == HandlesStyle.HatchFrame) block replace the DrawingBrush hatchBrush constructor call second argument "Color.Black" with "rgb". We are releasing Wpfdiagram version 2 beta this week.
g.
