Normal Topic performance of adding item into diagram (Read 1254 times)
billcch
Jul 26th, 2008 at 12:55am
// diagram1 is a MindFusion.Diagramming.Diagram
// item is a ShapeNode
this.diagram1.Items.Add(item);
this line called 37 times, and took 14.8881 seconds (0.4024 sec / per call)
2.
// item is a TableNode
this line called 17 times, and took 8.9669 seconds (0.5275 sec / per call)
We are not satisfying with this performance, how can we improve the performance?
BTW: we are using FC.Net Pro 5.1.0, and undo is disabled.
Re: performance of adding item into diagram
Reply #1 - Jul 28th, 2008 at 8:48am
If the diagram contains some links with AutoRoute enabled, each of them might be re-routed after each call to Items.Add(item). Either create the links after all nodes are created, or enable link auto-routing after the nodes have been created.
