Normal Topic Behavior select only (Read 2693 times)
digit
Jul 28th, 2008 at 7:18am
How do i set the diagram view behavior to select only? I need to prevent user deleting, or altering a node or link and prevent user from adding new node or link.
Re: Behavior select only
Reply #1 - Jul 28th, 2008 at 9:41am
Set Behavior = Modify, and either call Cancel from the StartModifying event handlers, or set EnabledHandles = None for all nodes.
digit
Reply #2 - Jul 29th, 2008 at 12:23am
I tried the following:
    Private Sub Diagram_NodeStartModifying(ByVal sender As Object, ByVal e As MindFusion.Diagramming.NodeValidationEventArgs) Handles Diagram.NodeStartModifying
       e.Cancel = True
    End Sub
but this still allowed a user to delete. So I added this as well:
    Private Sub Diagram_NodeDeleting(ByVal sender As Object, ByVal e As MindFusion.Diagramming.NodeValidationEventArgs) Handles Diagram.NodeDeleting
       e.Cancel = True
    End Sub
But this causes a crash.
My aim is to allow a user to select nodes only (not links) and to raise my own event from this selection, but prevent a user from moving, modifying or deleting a node.
Reply #3 - Jul 29th, 2008 at 7:10am
Set DiagramView.DelKeyAction = None to prevent users from deleting nodes. Set Locked = true for all links to prevent users from selecting them.
digit
Reply #4 - Aug 1st, 2008 at 4:19am
Perfect thank you.
