Normal Topic Background color of ControlNode (Read 1286 times)
Mettler
Jul 30th, 2008 at 2:49pm
Hi
I'm using FlowChart.Net 5.x in our project since two weeks. I'm using the ControlNode class in which I host a simple UserControl (contains a TableLayout, a PictureBox and two Labels). The background color of all Controls in the UserControl and the one of the UserControl itself is Set to System.Drawing.Color.Transparent.
I add the ControlNodes to the diagram this way:
ControlNode node = new ControlNode(this.diagram);
node.ControlMouseAction = ControlMouseAction.SelectNode;
this.diagram.Nodes.Add(node);
TestControl deviceView = new TestControl();
node.Control = deviceView;
The background colour of the diagram is set to White.
Unfortunately the Nodes background is painted in Gray instead White as I expected. Any ideas?
Re: Background color of ControlNode
Reply #1 - Jul 30th, 2008 at 4:57pm
This could be the shadow color. Set ShadowsStyle = None to disable all shadows, or set ControlNode.ShadowColor = Transparent if you want to hide the shadows of particular nodes.
