Hot Topic (More than 10 Replies) java.awt.HeadlessException (Read 11170 times)
tmtton
Aug 6th, 2008 at 7:39pm
We try to run a simple program remotely on a new system that doesn't have a monitor attached to the cpu unit (i.e. application deployed on that remote server, application display directed to a local screen via microsoft windows remote desktop connection). The following exception occurs. On line 95 of the loadDiagram function, it is simply Diagram diagram = new Diagram();
at sun.awt.HeadlessToolkit.getScreenResolution(HeadlessToolkit.java:203)
at com.mindfusion.diagramming.Diagram.setImageDpiX(Unknown Source)
at com.mindfusion.diagramming.Diagram.<init>(Unknown Source)
at com.xxx.yyy.zzzDiagram.loadDiagram(zzzDiagram.java:95)
tmtton
Re: java.awt.HeadlessException
Reply #1 - Aug 7th, 2008 at 2:04am
Is there a workaround for this problem? For this particular program, I just want to create a Diagram instance, have it load a XML document, and do additional processing based on the document content. This system needs to stay headless.
Online
Reply #2 - Aug 7th, 2008 at 7:47am
We'll have to find all places in the JDiagram code where that could happen and add GraphicsEnvironment.isHeadless() checks to avoid the exception. I will send you a new version of the JAR file when thats ready.
Online
Reply #3 - Aug 8th, 2008 at 4:31pm
I've emailed you the updated JAR file.
tmtton
Reply #4 - Aug 11th, 2008 at 7:53pm
It works great. We appreciate your tremendous support.
raymondpon
Reply #5 - Sep 26th, 2008 at 5:42pm
Could you also email me the updated JAR file? I am in the same situation and am running into the same problem as well.
Reply #6 - Sep 27th, 2008 at 10:19am
Here is a trial version:
https://mindfusion.eu/_temp/headless.zip
If you are our licensed customer, please email us your order number or some registrations details you provided with the purchase.
cpmjones
Reply #7 - Nov 8th, 2012 at 5:46pm
Is this still handled?
We have seen the following exception running on a Linux environment:
SEVERE: null
        at sun.awt.HeadlessToolkit.createCustomCursor(Unknown Source)
        at com.mindfusion.diagramming.DiagramView.a(Unknown Source)
        at com.mindfusion.diagramming.DiagramView.<init>(Unknown Source)
Chris
Reply #8 - Nov 9th, 2012 at 8:09am
We haven't removed any checks for headless environment, so perhaps that createCustomCursor method started throwing HeadlessException exception in more recent versions of Java. Our developer will check that for next release.
I'm not sure if that will help you though. It seems even if you create DiagramView, you can't add it to a root window since the JFrame constructor throws a HeadlessException too.
cpmjones
Reply #9 - Nov 12th, 2012 at 10:02am
What we have is a servlet running in Tomcat generating a PNG file for the http response so no need for any JFrame.
Chris
Reply #10 - Nov 12th, 2012 at 10:21am
Then you shouldn't need a DiagramView either. You can create an image using solely the Diagram class.
cpmjones
Reply #11 - Nov 12th, 2012 at 4:58pm
We took out the DiagramView and its working now.
Thanks yet again for your response  Smiley
