Normal Topic TimeTable view - scroll position (Read 2209 times)
BenWTS
Aug 7th, 2008 at 3:39pm
I'm trying to ensure that the start of my work time hours is visible when I load up the control or change the work time start hour through code but am having a hard time.
For example, I've setup our use of the control to contain multiple "groups". Each group can specify the work time hours, so Group 1 could be 9-5 and Group 2 could be 4-10. When I switch from group 1 to group 2 I want the scroll to be set in such a way that 4pm is visible.
I've tried using the .EnsureVisible command but it doesn't seem to work well after I change the work time hours for the control.
I could probably try and calculate a value for ScrollPosition directly, but is there a way to determine what the max scroll position is? Because it's also possible for the CellTime to switch when going from Group 1 to Group 2.
Any help would be appreciated.
Re: TimeTable view - scroll position
Reply #1 - Aug 8th, 2008 at 7:04am
I am using the EnsureVisible method and it seems to work well. Here is my code:
calendar1.EnsureVisible(
      calendar1.TimetableSettings.Dates[0] +
      TimeSpan.FromHours(calendar1.TimetableSettings.WorkTimeStartHour));
I am getting the first displayed date in the timetable view and then I add the number of hours specified by WorkTimeStartHour to receive the exact date and time of the first cell in the work period.
Another method with similar effect would be, as you suggested, to manually calculate the desired scroll position. Here is a sample code to achieve this:
long ticks = TimeSpan.FromHours(calendar1.TimetableSettings.WorkTimeStartHour).Ticks -
      TimeSpan.FromMinutes(calendar1.TimetableSettings.StartTime).Ticks;
long cell = calendar1.TimetableSettings.CellTime.Ticks;
int scroll = (int)(ticks / cell);
calendar1.VScrollPos = scroll;
BenWTS
Reply #2 - Aug 8th, 2008 at 3:13pm
Thanks again Meppy. The 2nd solution worked for me.
