Normal Topic Selection after load of custom ndoe type (Read 5717 times)
jdd48
Aug 11th, 2008 at 2:14am
After saving a diagram and then loading it again from disk, I've noticed that before I can select individual nodes and have the moving/sizing handles show up, I must first highlight all of the nodes, then click on the entire selection for the handles to show up on all of the nodes. Only after that can I individually select the custom nodes. Is this a bug, or do I need to maybe set some other property after loading the diagram from disk? Thanks.
Re: Selection after load of custom ndoe type
Reply #1 - Aug 11th, 2008 at 6:32am
Are you using binary or xml serialization? What happens if you call Selection.Clear() just after loading?
jdd48
Reply #2 - Aug 11th, 2008 at 11:18am
I'm serializing with the BinaryWriter and BinaryReader provided in the SaveTo and LoadFrom methods. Clearing the selection just after load doesn't seem to remedy the situation. Thanks.
Reply #3 - Aug 11th, 2008 at 12:10pm
and you are calling base.LoadFrom() from your custom node LoadFrom implementation?
jdd48
Reply #4 - Aug 11th, 2008 at 1:04pm
Yes - the base is called in both LoadFrom and SaveTo. Additional info - after the file is opened, I can add more custom nodes, and they are immediately selectable. However, the existing ones loaded from the file still are not individually selectable until they are all selected and clicked at least one time.
Reply #5 - Aug 11th, 2008 at 1:24pm
could you email the file and your custom node code to support@mindfusion.eu?
10x
jdd48
Reply #6 - Aug 11th, 2008 at 1:51pm
Done.
Reply #7 - Aug 11th, 2008 at 2:04pm
It works fine if you call the base class constructor -
public CustomNode(Diagram dgm) : base(dgm)
jdd48
Reply #8 - Aug 11th, 2008 at 2:48pm
Very nice. A bit upset with myself that I didn't think of it before. Thanks!
Reply #9 - Aug 11th, 2008 at 3:02pm
no worries Smiley
