Hot Topic (More than 10 Replies) Get Value Node Javascript (Read 4013 times)
Eli1983
Aug 12th, 2008 at 11:48am
Hi!!
Sorry about my english, not native speaker ^^U
I need to get the node identifier wich is automatically generetad when the node is added, with javascript.
I've tried using getNode(), but I can only access to the text value, not the ID.
Any help?
Re: Get Value Node Javascript
Reply #1 - Aug 12th, 2008 at 12:29pm
There aren't any automatically generated identifiers. You can assign your own id-s to the Tag property of nodes.
HTH
Eli1983
Reply #2 - Aug 12th, 2008 at 12:45pm
How can I assign my own id-s to the Tag property of nodes when I add a node in mode design to diagram?
Thanks in advance.
Reply #3 - Aug 12th, 2008 at 1:34pm
Handle the NodeCreated event, and set the e.Node.Tag to the id value you want to use, for example
e.Node.Tag = (new Guid()).ToString();
HTH
Eli1983
Reply #4 - Aug 13th, 2008 at 8:04am
I defined the event this:
diagramView.Diagram.NodeCreated += new NodeEventHandler(Diagram_NodeCreated);
  protected void Diagram_NodeCreated(object sender, NodeEventArgs e)
       throw new Exception("The method or operation is not implemented.");
But the exception doesn´t throw.
I tried the same whith NodeDeleted event and not ocurred nothing
What am I doing wrong?
Thanks for all!
Reply #5 - Aug 13th, 2008 at 8:15am
Hi, are you using the Windows Forms Flowchart.NET control?
Eli1983
Reply #6 - Aug 13th, 2008 at 8:45am
Sorry, I´m using the NetDiagram :$
But these events not working same?
Reply #7 - Aug 13th, 2008 at 9:02am
Nope. You must set DiagramView.NodeCreatedScript to the name of a JS function that will handle the event, e.g.
function onNodeCreated(sender, e)
e.getNode().setTag(...);
I don't know if there is a method to generate GUID in JS, but you can use another kind of ID, for example the current time + the number of items in the diagram at this time.
HTH
Eli1983
Reply #8 - Aug 13th, 2008 at 9:11am
First sorry about the mess
In server side I get the IndexOf of nodes of my diagram this way:
  foreach (DiagramNode di in diagramView.Diagram.Nodes)
               nodosiniciales.Add(diagramView.Diagram.Nodes.IndexOf(((ShapeNode)di)));
Now I want to get this value from javascript
Is there any way to do it?
Thanks for advance!!
Reply #9 - Aug 13th, 2008 at 1:27pm
You can do it as below with the Java API -
diagramView.getDiagram().getNodes().indexOf(di)
however indexOf does a linear search, and you'd better do that using an integer counter
for (i = 0; i < ...getNodes().size(); ++i)
nodosiniciales.add(i);
To me that looks the same as your foreach ... indexof ... loop.
HTH
Eli1983
Reply #10 - Aug 14th, 2008 at 9:19am
it works fine!
Thanks for the help!!
