Normal Topic Custom Table Node does not serialize property (Read 2184 times)
Seablade
Aug 12th, 2008 at 7:18pm
Hi.
I'm using the trial version 5.
I have a derived TableNode class that has a custom property.  When I save the diagram to a stream  and then restore the diagram, the custom property has not been restored.
Is this a bug or is this designed behavior?  If it's designed behavior, how can I save custom data with my TableNode?
Mike
Online
Re: Custom Table Node does not serialize property
Reply #1 - Aug 13th, 2008 at 8:01am
Have you implemented the SaveTo and LoadFrom methods? See the IconNodes sample project for an example.
HTH
Seablade
Reply #2 - Aug 27th, 2008 at 2:19pm
I finally found them but it took a while.  Once I did and implemented some code to save the custom variables, it seemed to serialize properly.
Thanks.
