Normal Topic Layout.Arrange causing Element resize (Read 2305 times)
Paul Eden
Aug 15th, 2008 at 3:23pm
Hi
All of a sudden, when using a custom diagram behavior and using a customnodetype of my own creation (composite control), calling the Arrany method resizes my custom elements to 0,0.  Node created programatically are not effected. My control functions OK as I have if fucntioning in a different app (also on a diagram control in this manor).  I've seen this happen with a third party control in an intermittent way.
  Any suggestions as to what could cause this?
Many thanks
Re: Layout.Arrange causing Element resize
Reply #1 - Aug 15th, 2008 at 3:47pm
please check if the same happens with the v2 beta -
https://mindfusion.eu/_beta/WpfDiag2Beta.zip
thanks
Paul Eden
Reply #2 - Sep 2nd, 2008 at 11:56am
I can now confirm that arrange works as expected with V2.
