Normal Topic Node : selection through text or attached node (Read 2147 times)
dku
Aug 20th, 2008 at 9:06am
I've 2 questions :
1) Is that possible to select a node by clicking on its text ? (text is below the node - custom shape node)
2) I've a node with another node attached to it as a label. Is that possible that clicking on the slave node fire the selection for the master node ?
Didier
Re: Node : selection through text or attached node
Reply #1 - Aug 20th, 2008 at 11:18am
1) That's not possible.
2) You could do this by handling the NodeClicked event. Assuming your label nodes are locked:
if (e.Node.Locked)
     diagram.Selection.Change(e.Node.MasterGroup.MainItem);
dku
Reply #2 - Aug 20th, 2008 at 11:53am
Ok, thanks.
For (1), I can build a node with a label (built as an attached node) and then use method (2).
Bye
Didier
