Normal Topic Locate dates in resource view with only 1 item (Read 1649 times)
dt-devman
Aug 21st, 2008 at 11:37am
I am using vb.net 2.0 framework. I have a selection of resources over a date range and want a collection object of all individual dates, regardless of resource, where there is only one item in that date/cell
any help or advise would be most gratefull
Re: Locate dates in resource view with only 1 item
Reply #1 - Aug 21st, 2008 at 12:00pm
Use the Schedule.GetAllItems method, passing the start time and end time of a cell of interest (use the override that does not specify a resource). Then check the number of elements in the returned item collection. You can do this for all cells in the interval and keep the dates that match your criteria in a dedicated collection.
