Normal Topic How to force link to connect to anchor point (Read 1362 times)
egreen
Aug 21st, 2008 at 5:32pm
I have a ShapeNode with an assigned anchor pattern. When I connect links programatically, they connect fine to the anchor points, however as a user when I move a link's origin/dest. and place it on any node, it does not connect to any of the anchor points (proof of this is that the anchor point index returned is "-1" when I query which anchor point it connected to). Is there any way to force the behavior to be such that links will connect only to the anchor point?
Thanks.
Re: How to force link to connect to anchor point
Reply #1 - Aug 21st, 2008 at 6:04pm
Set Diagram.SnapToAnchor = OnCreateOrModify.
egreen
Reply #2 - Aug 21st, 2008 at 6:13pm
used diagram1.SnapToAnchor = SnapToAnchor.OnCreateOrModify
Works like a charm. Thanks a lot.
