Normal Topic undo layout arrange (Read 1199 times)
bknaylor
undo layout arrange
Aug 27th, 2008 at 1:58pm
Is there a way to filter the undo command manager so that I can undo a layout arrange only?
Re: undo layout arrange
Reply #1 - Aug 27th, 2008 at 2:15pm
You can filter what commands get stored in the undo history by handling the ActionRecording event. For example, you could set Cancel = true for ModifyCmd objects, which are stored for items modified by the user. The Layout classes create CompositeCmd commands, so set Cancel = false for them.
bknaylor
Reply #2 - Aug 27th, 2008 at 2:22pm
This worked. Thank you very much.
