Normal Topic inactive shapes (Read 2656 times)
ebibnet
inactive shapes
Aug 25th, 2008 at 6:30pm
Is it possible to prevent a postback for certain shapes ???? Somehow i am not able to find it .
excerpt code
                       ShapeNode MasterNode = (ShapeNode)diagram.FindNode(NodePrefixType.ShowUnitDetails + fromId);
                       ShapeNode footerNode = diagram.Factory.CreateShapeNode(MasterNode.Bounds.X ,
        MasterNode.Bounds.Y - 4, 4, 4);
                       //MasterNode.AttachTo(footerNode, AttachToNode.TopCenter);
        footerNode.Image = "ImgProcess.gif";
         footerNode.Transparent = true;
         footerNode.ImageAlign = ImageAlign.Center;
         footerNode.ResizeToFitImage();
Re: inactive shapes
Reply #1 - Aug 25th, 2008 at 7:30pm
Are you using Flowchart.NET and the HtmlBuilder class? In that case, setting Hyperlink to an empty string should be enough to prevent postback.
ebibnet
Re: inactive shapes
Reply #2 - Aug 25th, 2008 at 8:40pm
I tried this but it gives me an error
"Object reference not set to an instance of an object."
I'm using latest version of Netdiagram.
Definition in page
<ndiag:diagramview
                       id="m_diagramView"
                       runat="server"
                       Visible="false"
                       ClientSideMode="ImageMap"
                       OnNodeClicked="HandleDiagramNodeClick"
                       Behavior="DrawShapes"
                       ShowScrollbars="True">
                   </ndiag:diagramview>
Are there other possibilities
Thanks !!!!
Re: inactive shapes
Reply #3 - Aug 26th, 2008 at 7:52am
In Netdiagram you can disable postback for some node by setting its Hyperlink to "javascript:void(0)". Setting the Hyperlink value will cause a NullReferenceException only if your DiagramNode variable is not initialized.
ebibnet
Re: inactive shapes
Reply #4 - Aug 31st, 2008 at 10:06pm
Perfect ,
This did the trick, Thanks,
