Normal Topic Unod Redo (Read 625 times)
balajigcs
Unod Redo
Sep 1st, 2008 at 5:31am
  I am using the undo redo operations in my flowchart editor.first i add a node to diagram view.. actually i am creating node and links separately.. so first undo is working properly after that the redo is not working properly..means the links are not arranging properly in the node.. how to work properly this problem.. would u plz give the reply..
Thanks & Regards,&&&&Balaji
