Normal Topic Diagram auto scrolling speed (Read 1634 times)
xan
Sep 2nd, 2008 at 3:25pm
Another quick question...
Is there a built in way to control the speed at which the diagram auto-scrolls, for example when dragging a node, or the end of a link, outside the bounds of the diagram, or the bounds of the view?
The default speed is a little slow for my app but I have not found any way of speeding it up internally.
As always thanks for your help Smiley.
Cheers,
xan
Re: Diagram auto scrolling speed
Reply #1 - Sep 3rd, 2008 at 6:58am
Currently there is no way to control the auto-scroll speed using the public API. We'll add some property to let you do this with the next release.
xan
Reply #2 - Sep 12th, 2008 at 2:59pm
That would be great - thankyou!
Another question related to diagram scrolling:
Is there a way to have the diagram size increase when you scroll to the edge in the same was as when you drag an element off the edge of the diagram?
I'm attempting to do this by using a ScrollChanged event handler function. This checks the current view bounds and if the view is currently at the edge of the digram, it extends it.
However, it's not working as I expected, and further more, the ScrollChanged event is (understandable) not called if the diagram is zoomed out to the point where it cannot be scrolled!
My code is similar to the below, any suggestions as to a different approach would be great.
Cheers,
xan.
//snipped handler function to illustrate what I'm trying to do  :)
private void diagramView1_ScrollChanged(object sender, EventArgs e)
           PointF docPointTL = diagramView1.ClientToDoc(PointToClient(diagramView1.Bounds.Location));
           float docLeft = docPointTL.X;
           if (docLeft <= diagram1.Bounds.Left)
                   RectangleF bounds = diagram1.Bounds;
                   bounds.X -= extend;
                   diagram1.Bounds = bounds;
Reply #3 - Sep 14th, 2008 at 7:27am
Handle both ScrollChanged and ZoomFactorChanged events. Then you could use DiagramView.ClientToDoc(DiagramView.ClientRectangle) to find what part of the diagram is currently visible in the view. If you detect that any of the coordinates of the visible rect are near or outside of diagram.Bounds, increase the diagram size.
