Normal Topic display a html page in winform (Read 4903 times)
parapara
susan
Sep 5th, 2008 at 7:29am
this is the code of in winform:
[code]
Page page = new Page();
DiagramView dv = new DiagramView();
page.Controls.Add(dv);
dv.ClientSideMode = ClientSideMode.ImageMap;
dv.Width = new Unit(400, UnitType.Pixel);
dv.Height = new Unit(300, UnitType.Pixel);
dv.Style.Add("border", "solid 1px gray");
Diagram diagram = dv.Diagram;
diagram.LoadFromXml("c:\\Diagram.xml");
System.IO.StringWriter sw = new System.IO.StringWriter();
HtmlTextWriter htw = new HtmlTextWriter(sw);
dv.RenderControl(htw);
[/code]
the value of HtmlTextWriter:
[code]
<div style="height:300px;width:400px;border:solid 1px gray;">
<table cellpadding='0' cellspacing='0' width='680px' height='529px' cols='1px'><tbody>
<tr height='0px'>
</div>
[/code]
the result is wrong.
I want to create a html of Diagram,and display it in winform with the control of System.Windows.Forms.WebBrowser.
Re: display a html page in winform
Reply #1 - Sep 5th, 2008 at 10:05am
The HTML rendered by DiagramView.Render relies on ImageGen.aspx to generate the image bytes, so it's of not much use if you want to display the diagram as a static page without running a web server. Try the HtmlBuilder.CreateImageHtml method instead.
parapara
susan
Reply #2 - Sep 8th, 2008 at 3:04am
well
I tried this method,another problem emerged.
if i set Cell.HyperLink,the result of HtmlBuilder.CreateImageMap is null.
[code]
Diagram d = this.DiagramView1.Diagram;
TableNode tn = d.Factory.CreateTableNode(10, 10, 30, 30,2,2);
tn[0, 0].Text = "links";
tn[0, 0].HyperLink = "http://mindfusion.org";
HtmlBuilder hb = new HtmlBuilder(d);
string imagemap = hb.CreateImageMap("maps");
[/code]
the content of imagemap do not include Cell.HyperLink.
imagemap:[code]
<MAP NAME='maps'>
</MAP>
[/code]
parapara
susan
Reply #3 - Sep 8th, 2008 at 7:30am
The problem has been resolved,thanks! :)
Reply #4 - Sep 8th, 2008 at 8:05am
