Normal Topic ArrowAnchoring (Read 2184 times)
Stuart
Short, fat and bald, that's
me.
ArrowAnchoring
Sep 5th, 2008 at 2:58pm
I'm evaluating FCX for a project I'm working on to create a GUI for workflow processes generated by our software.
I've just had a little play and have created a simple diagram with a 'Decision' box and 2 rectangular boxes. I've added arrows to the 'red' node and the 'green' node on the decision box and connected them to the 2 rectangular boxes.
Nothing clever so far.
I've added a button to the form to force a call to 'ArrangeDiagram' using a TreeLayout. As you can see below I'm explicitly setting the ArrowAnchoring property to 'ancKeep' but when I press the button the chart redraws with BOTH arrows coming out of the bottom (green) node of the decision box.
Is this a bug? Am I doing it wrong?
procedure TForm1.btnRearrangeAsTreeClick(Sender: TObject);
var
  tl : TreeLayout;
begin
  tl := CreateCOMObject(CLASS_TreeLayout) as TreeLayout;
  tl.NodeSpacing := 100;
  tl.LevelSpacing := 100;
  tl.ArrowAnchoring := ancKeep;
  FlowChart1.ArrangeDiagram(tl);
end;
Stuart
-- &&Stuart
YIM
Re: ArrowAnchoring
Reply #1 - Sep 8th, 2008 at 7:24am
ancKeep specifies that ArrangeDiagram should preserve to which points of nodes' AnchorPattern links connect. Are you sure your links are connected to any anchor points prior to running the layout function?
Stuart
me.
Re: ArrowAnchoring
Reply #2 - Sep 8th, 2008 at 8:26am
It must have been a Friday afternoon problem, 'cos I can't get it to happen now! Roll Eyes
Sorry to have bothered you.
-- &&Stuart
YIM
Re: ArrowAnchoring
Reply #3 - Sep 8th, 2008 at 8:32am
