Normal Topic Shape sharing library? (Read 1123 times)
IQMS
Sep 5th, 2008 at 6:02pm
Is there a standard way to share libraries of custom shapes/nodes that I'm not seeing?
We're in need of a plant operation/manufacturing node set similiar to what you see here:
http://en.wikipedia.org/wiki/Process_flow_diagram
I'm sure I'm not the first to need this.
Thanks!
Re: Shape sharing library?
Reply #1 - Sep 8th, 2008 at 7:40am
We do not provide any stock shape libraries - you can either create your own Shape definitions, or use images. We could add these shapes to the control's built-in list of shapes - can you point us to where we can see the names of the shapes from that image?
