Normal Topic Change cursor on mouse hover (Read 2131 times)
srlevitt
Sep 11th, 2008 at 8:10pm
Is there a way to change the cursor from the default hand to e.g. cross when the mouse is over an anchor point?
When the mouse is not over anything, I want the cursor to be the standard arrow.
when the mouse is over a shape node, I want it to be a hand.
When the mouse is over one of my anchor points, I want it to be a cross.
Re: Change cursor on mouse hover
Reply #1 - Sep 12th, 2008 at 8:31am
You will have to create a custom Behavior class and override its SetMouseCursor method. The sample code here shows how to detect whether the mouse is over an anchor point:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=121025732...
srlevitt
Reply #2 - Sep 12th, 2008 at 2:56pm
Yes, that works fine thanks. The only problem I have now is that the user can click and move the mouse and a new shape is drawn. I do not want this to happen. Previously, moving the mouse like this created a shaded "selection" area. I guess it's the fact I am now using behavior.custom rather behavior.drawLinks for View.Behavior. Any ideas? Thanks.
srlevitt
Reply #3 - Sep 12th, 2008 at 3:38pm
OK, stand easy. I found a way to do this by overriding StartDraw in my custom behavior, and returning  "new InteractionState(Diagram.Selection, 8, Action.Create);"
Thanks anyhow  Smiley
