Normal Topic Text overflow on CalendarView.Timetable view (Read 9067 times)
trash2all
Sep 16th, 2008 at 9:53am
hi,
i have 2 appointments on the same hour and their text overflows although it have enough height.
the text overflows horizontally to the left side.
what can i do?
thanks in advance...
Re: Text overflow on CalendarView.Timetable view
Reply #1 - Sep 16th, 2008 at 10:29am
I am not sure I understand your problem. Can you post a picture of it or give more detailed description?
trash2all
Reply #2 - Sep 17th, 2008 at 1:18pm
Reply #3 - Sep 17th, 2008 at 2:11pm
As far as I understand you are worried by the fact that the header text does not get clipped and extends outside of the item cell. Is that correct?
I am trying to reproduce this here, but the text gets clipped as expected. Can you try and see if the same happens if you are using English texts? Also, which version of PocketPlanner are you using?
trash2all
Reply #4 - Sep 29th, 2008 at 7:13am
- yes
- PocketPlanner version 4.1.0.0
NOTE:
All appointments have the same text:
AAA BBB 3123 CCC DDD i841 cal
but only text of one appointment is displayed.
thanks for your help...
Reply #5 - Sep 29th, 2008 at 8:13am
Try to download and use the last available version of PocketPlanner (4.3):
https://www.mindfusion.eu/PocketPlannerTrial.zip
There are some issues with item texts that have been fixed there.
trash2all
Reply #6 - Oct 2nd, 2008 at 12:40pm
HI meppy,
Did this issue was solved on version 4.2/4.3?
thanks again for your help...  Wink
Reply #7 - Oct 3rd, 2008 at 6:30am
My testing indicates that the text appears to clip more efficiently in 4.3. I can only suggest you download the 4.3 trial from our site and have a try with it.
Let me know if there is any improvement.
