Normal Topic WpfDiagram 2.0 with sources, missing refernces (Read 3251 times)
dku
Sep 17th, 2008 at 9:17am
I've become recently the version 2.0 with sources. I've tried to compile it, and 2 dlls are missing :
  • Mindfusion.Common.dll
  • Mindfusion.Pdf.dll
I've found them and I should be able to compile when setting the path on them. BUT, it means that we have a part of the library without sources (only dlls), it means that we will unable to rebuild the whole stuff completely.
When buying "with sources", the idea is to have something buildable from scratch.
What is your strategy ?
Didier
Re: WpfDiagram 2.0 with sources, missing refernces
Reply #1 - Sep 17th, 2008 at 12:31pm
Ok, we'll add these sources to the installer kit for next release. I can email them to you now if you need them that much.
dku
Reply #2 - Sep 17th, 2008 at 12:35pm
Yes, please.
I've sent to you per e-mail my address.
Didier
Reply #3 - Sep 17th, 2008 at 1:23pm
i've just emailed them.
dku
Reply #4 - Sep 18th, 2008 at 7:32am
Thanks a lot.
