Normal Topic subclass DiagramLink (Read 1847 times)
deanhully
Sep 17th, 2008 at 5:18pm
Is it possible (and effective) to subclass DiagramLink?
Dean
Re: subclass DiagramLink
Reply #1 - Sep 17th, 2008 at 6:08pm
It is possible, for example adding new properties and customizng the appearance by overriding the Draw method should not be a problem. What do you need subclassing DiagramLink for?
deanhully
Reply #2 - Sep 18th, 2008 at 1:37am
In our diagram a link may actually represent several links between nodes. If I click on the displayed link I will need to load this info into a toolbox. I was considering subclassing vs maintaining the data separately.
Btw, Stoyan,  thanks very much for your quick and knowledgeable responses.
Dean
Reply #3 - Sep 18th, 2008 at 6:57am
You might store that information in the Tag property of links, without subclassing. Otherwise you could subclass, define a new property for the data, override the SaveTo and LoadFrom methods to implement serialization for the new property, and use the RegisterItemClass method to enable serialization for your link class.
