Hot Topic (More than 10 Replies) Container Node (Read 4735 times)
balajigcs
Container Node
Sep 18th, 2008 at 4:48am
   I am adding the node into the container and folded that container after that I am going to save that diagram in to xml format and once again load that xml file.. so loading the xml file is not done properly.. otherthan that all are saving and loading properly only..
Would you please help me how to rectify this problem...
Thanks & Regards,&&&&Balaji
Re: Container Node
Reply #1 - Sep 18th, 2008 at 7:04am
I can't see anything wrong with that. Could you email the XML file to support@mindfusion.eu?
Re: Container Node
Reply #2 - Sep 18th, 2008 at 10:50am
So you are using a class derived from ContainerNode? We'll investigate why this happens in the next few days. For the time being, override LoadFromXml and after calling base.LoadFromXml set item.Visible = !container.Folded for all contained items.
balajigcs
Re: Container Node
Reply #3 - Sep 19th, 2008 at 10:32am
yes,I am deriving from containernode. did u get any idea how it is coming like this.
Thanks & Regards,
Balaji
balajigcs
Re: Container Node
Reply #4 - Sep 19th, 2008 at 10:35am
I have one doubt.. for containerNode having the events like..onNodeSizeChanged and  onNodeDroped.. In which MindFusion Version they are working..
Re: Container Node
Reply #5 - Sep 19th, 2008 at 11:45am
There are the ContainerChildAdded and NodeModified events, if that's what you are asking about.
balajigcs
Re: Container Node
Reply #6 - Sep 19th, 2008 at 12:41pm
no these are  the events..
ContainerNode node = new FPIContainerNode();
node.onNodeDroped += new NodeEventHandler(OnNodeAdded);
node.onNodeSizeChanged += new NodeValidationEventHandler(OnContNodeSizeChanged);
Re: Container Node
Reply #7 - Sep 19th, 2008 at 3:42pm
There have never been any events defined in the ContainerNode class. However there are OnChildModified and OnDropOver methods that you can override in your FPIContainerNode class, and there are the ContainerChildAdded and NodeModified events defined in Diagram.
balajigcs
Re: Container Node
Reply #8 - Sep 22nd, 2008 at 8:32am
  In MinFusion samples FcDemo, we add nodes into the container and then folded the container then save the diagram into xml format. After that once again load that xml file then the container coming with folded,but the nodes in the container are showing outside.. once unfolded that container then its coming properly only...
So,please let me know how to solve this problem.
Re: Container Node
Reply #9 - Sep 22nd, 2008 at 12:49pm
Our developer will look into this in a few days. If you can't wait, there are a couple of possible workarounds. As mentioned earlier, since you are deriving from  ContainerNode, you could override the LoadFromXml method and set item.Visible = !container.Folded for all contained items after calling the base class implementation. Another option is to loop over all nodes in the diagram after calling Diagram.LoadFromXml, and do the same if they are in a container.
Re: Container Node
Reply #10 - Sep 23rd, 2008 at 10:27am
This version should set the visibility correctly:
https://mindfusion.eu/_temp/foldedctr.zip
balajigcs
Re: Container Node
Reply #11 - Sep 23rd, 2008 at 2:36pm
  Actually I have the licenced version midfusion dlls.. how can i get the licenced latest version dlls.
Re: Container Node
Reply #12 - Sep 23rd, 2008 at 3:39pm
Email your order id to our support email address and we'll send you back the dlls.
