Normal Topic Using Custom Item Types (Read 3938 times)
bmosbarg
Sep 19th, 2008 at 7:47pm
In the developers guide there is a tutorial called 'Using Custom Items Types' that I have been attempting to use to become familiar with FlowChart.net. I can not get past step 2 using VB.net. Is there another example that would show how to create a line object, a text object and an Arc object. These objects would then be resizable and movable.
Re: Using Custom Item Types
Reply #1 - Sep 20th, 2008 at 8:52am
This is a very basic Arc implementation:
http://mindfusion.eu/_samples/Arc.cs
You might play with the UpdateModify method to improve how mouse movement reflects on the angles. Currently it simply adds the horizontal mouse offset to the angles.
Take a look at the IconNodes sample to see how you might implement serialization for the SweepAngle and StartAngle properties.
This code lets the user draw Arc objects:
diagramView.Behavior = Behavior.Custom;
diagramView.CustomNodeType = typeof(Arc);
You could use Transparent ShapeNode objects to display text, instead of creating a class for text objects. As for lines, you might either use unconnected DiagramLink objects, or implement a Line class similar to Arc.
bmosbarg
Reply #2 - Sep 20th, 2008 at 5:02pm
Thanks so much for your prompt reply, this is a big help.
bmosbarg
Reply #3 - Sep 22nd, 2008 at 9:00pm
Is it possible to create a handle on the sweepangle and let the user click and drag the location?
Protected Overrides Sub UpdateModify(ByVal current As PointF, ByVal ist As InteractionState)
'Debug.Print(StartAngle & " -- " & sweepAngle)
sweepAngle = 90
'Can I make this a handle that the user can click and drag
End Sub
Reply #4 - Sep 23rd, 2008 at 7:18am
That sample already shows handles for both StartAngle and SweepAngle, but they might not be easy to spot if you are using the default SquareHandles style. For example set HandlesStyle to DashFrame, and you'll see the elliptical handles added by the Arc.DrawHandles implementation.
bmosbarg
Reply #5 - Sep 25th, 2008 at 7:00pm
The handle is not moving with the mouse correctly, is there a way to correct this?
Thanks.
Reply #6 - Sep 25th, 2008 at 7:52pm
Right, now it just adds the mouse X offset to the angles, so the pointer position and the angle-adjustment handles do not match. Instead, you could calculate the angle that the mouse pointer makes with respect to the arc center, and set the angle to that value. Check the CustomDraw sample - it has a method for conversion from Cartesian (X/Y) to polar (angle/radius) coordinates, which should help with this.
« Last Edit: May 31st, 2021 at 1:42pm by Slavcho »
bmosbarg
Reply #7 - Sep 25th, 2008 at 8:44pm
Thanks again for the prompt reply.
That is precisely what we are trying to accomplish.
bmosbarg
Reply #8 - Oct 2nd, 2008 at 4:20pm
I have successfully implemented a line class, but I am having difficulty using the handles to move and resize the line. Do you have any examples?
Thank you.
Reply #9 - Oct 3rd, 2008 at 10:20am
For lines you would not need to call the base class HitTestHandles and DrawHandles method. Just return 0 or 1 from HitTestHadles and render two selection handles in DrawHandles.
Assuming you have two PointF fields in the Line class, UpdateModify should set one of the points (depending on the current handle being dragged) to the InteractionState.CurrentPoint value. When either point changes, set Bounds to the smallest rectangle that contains both points, so that repainting and hit-testing work correctly.
