Normal Topic How to use resizeToFitText in a web page? (Read 2445 times)
FireFoxFreak
Sep 26th, 2008 at 10:51am
I have a problem using resizeToFitText in a web page's Javascript as I cannot figure out how to create an instance of FitSize:
function load()
var applet = document.getElementById("fcapplet");
fc = applet.getDiagram();
var node = fc.getFactory().createShapeNode(0, 0, 50, 50);
node.setText("Node #1")
//This does not work in JavaScript !!!!!!
node.resizeToFitText(FitSize.KeepHeight);
Please help.
Best regards.
Re: How to use resizeToFitText in a web page?
Reply #1 - Sep 26th, 2008 at 10:59am
That happens because inadvertently we've changed the FitSize type to enum, instead of declaring int constants as possible FitSize values. We'll return it back to int constants in next release. Until then you can use the following method to get the enum value:
node.resizeToFitText(applet.getScriptHelper().getConstant("FitSize", "KeepHeight"));
FireFoxFreak
Reply #2 - Sep 27th, 2008 at 6:51pm
This works for me - thanks Stoyo!
