Normal Topic Error after LoadfromXML for Custom Shape node (Read 4654 times)
tusharpateluk
Oct 1st, 2008 at 12:47pm
I have extended Shape node with some additional data. Saving diagram to XML works fine. While load the save xml file it throws me error "Object reference not set to an instance of an object".
I had override LoadFromXML and was getting this error after LoadFromXML was successfully completed. After further research, I found that error was coming from Draw method that was executing after the LoadFromXML.
Can anyone please help me to fix this error. What exactly should I write in Draw method to fix this issue. Or their is any other solution.
Below is the stack trace of the error. Looking forward to your reply.
   at MindFusion.Text.Layout.x8a1888a014534b73(Int32 xb1c30745a1525188)
   at MindFusion.Text.Layout.Draw(Double xOff, Double yOff, RenderTextCallback renderCallback, DrawTextHint hint)
   at MindFusion.Diagramming.Wpf.ShapeNode.xeda13f64d938197c(DrawingContext x41347a961b838962, RenderOptions xdfde339da46db651)
   at MindFusion.Diagramming.Wpf.ShapeNode.xc79d59e9288101bd(DrawingContext x41347a961b838962, Rect xa6236fc5cd405c4e, Boolean x2f9dabff87b2168b, Brush xb45de92d01a0ec1f, Pen x9c79b5ad7b769b12, RenderOptions xdfde339da46db651)
   at MindFusion.Diagramming.Wpf.ShapeNode.Draw(DrawingContext graphics, RenderOptions options)
   at Components.ValueObject.QuestionNode.Draw(DrawingContext graphics, RenderOptions options) in C:\Source\QuestionNode.cs:line 51
tusharpateluk
Re: Error after LoadfromXML for Custom Shape node
Reply #1 - Oct 1st, 2008 at 12:58pm
While handling the exception on the Draw method, if I don't throw any exception then execution continues and Diagram is loaded.
But, I am still not sure, if it is a bug or I might be missing something.
Below is the Draw method.
public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options)
try
base.Draw(graphics, options);
catch (Exception)
Please help me, if you have faced similar problem
Reply #2 - Oct 1st, 2008 at 1:49pm
Could you also post the LoadFromXml override code here?
tusharpateluk
Reply #3 - Oct 2nd, 2008 at 2:49pm
Below is the LoadfromXML method along with the SetCustomData method
protected override void LoadFromXml(XmlElement xmlElement, MindFusion.Diagramming.Wpf.XmlPersistContext context)
SetCustomData(xmlElement);
base.LoadFromXml(xmlElement, context);
private void SetCustomData(XmlElement doc)
question = new QuestionProperty();
question.StepNumber = doc.SelectSingleNode("Question/StepNumber").InnerText;
("Question/Explanation").InnerText;
question.Eval = doc.SelectSingleNode("Question/Eval").InnerText;
Reply #4 - Oct 2nd, 2008 at 3:02pm
Have you also overridden the OnLoad method by any chance?
tusharpateluk
Reply #5 - Oct 2nd, 2008 at 3:45pm
No, I have not override OnLoad method. Do I need to ?
As per my understanding and debugging, After LoadfromXML, draw method is called and once all the nodes are drawn then OnLoad method get's called.
Please let me know if you have any suggestion.
Reply #6 - Oct 3rd, 2008 at 10:26am
Could you email the QuestionNode code to support@mindfusion.eu? What value does the Text property have when the exception happens?
