Normal Topic Flowchart from a XML doc (Read 1086 times)
Harry
Oct 7th, 2008 at 11:12am
I want to show a flowchart during runtime and the flow should be taken from the XML file in ASP.net/C# . How to do this Can you provide me a sample example for this.??
what is your suggestion about the vision component of .net for this thing
best regards
Re: Flowchart from a XML doc
Reply #1 - Oct 7th, 2008 at 12:45pm
If you need to show the contents of an arbitrary XML file as a tree in Flowchart.NET, check the MainForm.LoadXML method in the FCDemo sample project. That sample comes with our Flowchart.NET Windows Forms control, but since the MindFusion.Diagramming API is the same in the WebForms version, you should be able to use it directly under ASP.NET with NetDiagram.
