Normal Topic How do i use the UndoManger? (Read 4034 times)
sm
Oct 8th, 2008 at 1:01pm
I'm new to netdiagram and am unable to find a way to undo user action.I need to undo the last user action which could be a change in the size of the node or the link.When i click on an "undo" button it should go back to the original shape.Can someone please help me with this?
Re: How do i use the UndoManger?
Reply #1 - Oct 8th, 2008 at 1:30pm
Currently undo can be used only on the client side in JavaApplet mode through the DiagramApplet API. You must handle the AppletStarted client side event, and call diagram.getUndoManager().setUndoEnabled(true) from the handler. Then the undo button click handler could call diagram.getUndoManager().undo().
sm
Reply #2 - Oct 10th, 2008 at 7:04am
I'm not able to get the getUndoManager method of Diagram.Am i missing something?
Thanks for your response.
Reply #3 - Oct 10th, 2008 at 10:56am
Assuming the JavaScript 'applet' variable refers to the DiagramApplet object, you can access the UndoManager instance like this:
var applet = <%= diagramView.AppletElement %>;
var um = applet.getDiagram().getUndoManager();
sm
Reply #4 - Oct 14th, 2008 at 8:40am
Thanks a lot ! It works perfectly Smiley
chieh
Reply #5 - Aug 18th, 2010 at 1:50pm
hello,
do you have any examples for redo/undo
I try it but it doesn't work
thanks
Reply #6 - Aug 18th, 2010 at 2:49pm
You can use undo/redo only in JavaApplet or Silverlight mode, and you must enable it from JavaScript. Assuming you've got an UndoManager instance in Java mode as shown above, call um.setUndoEnabled(true) to enable it.
