Normal Topic Drag/Drop (grid-aligned); Default drawing behavior (Read 3053 times)
jonsberndt
Oct 9th, 2008 at 3:25am
Two questions:
1) When a shape is dropped onto a diagram, is it possible to automatically make sure that the shape is aligned to the grid? I think I can do that algorithmically myself, but I was wondering if there is a property setting that handles this itself?
2) I'd like to make sure that the default diagram behavior (when the mouse drags a rectangle on the diagram) is that nothing at all happens. Right now, a shape object is drawn, but I'd like nothing to happen.
Re: Drag/Drop (grid-aligned); Default drawing beha
Reply #1 - Oct 9th, 2008 at 7:50am
1) You could call the Diagram.AlignPointToGrid method to find out which grid point is nearest to the mouse position, and call DiagramNode.Move to move the node there.
2) Set DiagramView.Behavior = DoNothing.
jonsberndt
Reply #2 - Oct 10th, 2008 at 1:56am
Stoyo wrote on Oct 9th, 2008 at 7:50am:
Well, the current Behavior is LinkShapes, which is good, since I can then link shapes that are already in the view. However, if I depress the left mouse button while the cursor is not over a shape, then the behavior is to draw a shape. I only want to prevent that latter behavior, not the linking.
Jon
Reply #3 - Oct 10th, 2008 at 6:34am
Set DiagramView.Behavior = DrawLinks.
jonsberndt
Reply #4 - Oct 11th, 2008 at 4:12am
Stoyo wrote on Oct 10th, 2008 at 6:34am:
Yes, that's exactly what I was looking for.
I have to say it (or, *write* it!): FlowChart.NET is a really impressive piece of work!
Jon Berndt
Reply #5 - Oct 12th, 2008 at 9:51am
Thanks 8)
