Normal Topic shapedesioner.exe "split to line " error (Read 2300 times)
mahongquan
Oct 13th, 2008 at 7:42am
Method 'MindFusion.Tools.ShapeDesignerCtrl.xb2f06c7846241795.Create' not found.
mahongquan
Re: shapedesioner.exe "split to line " e
Reply #1 - Oct 13th, 2008 at 7:52am
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method 'MindFusion.Tools.ShapeDesignerCtrl.xb2f06c7846241795.Create' not found.
   at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
   at System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args)
   at MindFusion.Tools.ShapeDesignerCtrl.xbf362109f420e5ee.Create(Type isegmentImpl, PointF start, PointF end, ShapeDesigner d)
   at MindFusion.Tools.ShapeDesignerCtrl.xf8bf0f2f91d89729.Split(Type insertedType, Int32 segmentIndex, Point splitLocation, ShapeDesigner d)
   at MindFusion.Tools.ShapeDesignerCtrl.ShapeDesigner.menuItemSplitOnClick(Type segmentType)
   at MindFusion.Tools.ShapeDesignerCtrl.xc06f829a1acb28f9.menuItemClick(Object sender, EventArgs e)
   at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.MenuItem.MenuItemData.Execute()
   at System.Windows.Forms.Command.Invoke()
   at System.Windows.Forms.Command.DispatchID(Int32 id)
   at System.Windows.Forms.Control.WmCommand(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///D:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ShapeDesigner
    Assembly Version: 1.0.3121.24417
    Win32 Version: 1.0.3121.24417
    CodeBase: file:///G:/Program%20Files/MindFusion/FlowChart.NET%20Trial%20Version/Bin/ShapeD
esigner.exe
    CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e
089/System.Windows.Forms.dll
System
    CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/Sy
stem.Drawing.dll
ShapeDesignerCtrl
    Assembly Version: 5.1.0.30905
    Win32 Version: 5.1.0.30905
esignerCtrl.DLL
MindFusion.Diagramming.WinForms
    CodeBase: file:///G:/Program%20Files/MindFusion/FlowChart.NET%20Trial%20Version/Bin/MindFu
sion.Diagramming.WinForms.DLL
    Assembly Version: 5.1.0.30901
    Win32 Version: 5.1.0.30901
sion.Diagramming.DLL
ShapeListBox
    Assembly Version: 5.1.0.30906
    Win32 Version: 5.1.0.30906
    CodeBase: file:///G:/Program%20Files/MindFusion/FlowChart.NET%20Trial%20Version/Bin/ShapeL
istBox.DLL
System.Xml
    CodeBase: file:///D:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System
.Xml.dll
MindFusion.Common
    Assembly Version: 1.0.3083.21518
    Win32 Version: 1.0.3083.21518
sion.Common.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Reply #2 - Oct 13th, 2008 at 10:48am
Thank you for your feedback. This is fixed in version 5.1.1 which we are releasing tomorrow.
