Hot Topic (More than 10 Replies) printing in net diagram (Read 8588 times)
keropi
Oct 13th, 2008 at 10:49am
Hi, can someone let me know how to print the diagram using the net diagramming?
Re: printing in net diagram
Reply #1 - Oct 13th, 2008 at 10:58am
Since the ASP.NET process cannot access the printer, you cannot print on the server side. You could either call print() on the client side in JavaApplet mode, or use PdfExporter to create a PDF file and let the user print it. Another option is to run a Windows process that polls a directory for new diagram or PDF files and prints them.
keropi
Reply #2 - Oct 13th, 2008 at 12:03pm
Hi, thank you for your help, Will try the pdf way now.
bkernan
Reply #3 - Jul 15th, 2009 at 8:00pm
Hello, I was reviewing this thread thinking too that there was a diagramView.print() function for NetDiagram. Since October last year has any changes been made to allow printing for NetDiagram? Thanks
Reply #4 - Jul 16th, 2009 at 6:16am
Is there any problem when calling diagramView.print() ?
bkernan
Reply #5 - Jul 16th, 2009 at 12:25pm
Yes, where ever I try to use the method, I receive an error that it does not exist. I tried it in the javascript too:
protected void btnPrint_Click(object sender, EventArgs e)
       {  MindFusion.Diagramming.WebForms.DiagramView.print(); //errors that there is no definition for print()
and I tried
function printDiagram() {
           alert("gothere");
           var dvApplet = document.getElementById("diagramView");
           var dv = dvApplet.getDiagram();
           dv.print(); }
//errors object does not support property or method
I looked in the documentation and believe I am using it correctly. Any thoughts?
Reply #6 - Jul 16th, 2009 at 12:36pm
print() is a method of DiagramView. Try this:
dvApplet.getDiagramView().print();
bkernan
Reply #7 - Jul 16th, 2009 at 12:38pm
Works! Thanks!
bkernan
Reply #8 - Jul 16th, 2009 at 12:49pm
Now that I can see the area that it prints, it cuts off the left part of the diagram whats wider than the page if its in portrait mode. It scales the diagram to the proper height to fit on the page, but doesn't scale the width to fit. And vice versa for  the landscape print mode.
Please let me know if there is anything I can do to fix this  Smiley
Reply #9 - Jul 16th, 2009 at 1:13pm
The control does not scale automatically the diagram to fit the page. Are you printing to a real printer or some kind of a pdf printer?
bkernan
Reply #10 - Jul 16th, 2009 at 1:15pm
a real printer. I printed a test page.
Reply #11 - Jul 16th, 2009 at 2:59pm
Are you changing anything in DiagramView.PrintOptions?
I've added this to the OrgBrowser sample and printed a large tree, the result seems ok:
<button onclick="onPrint();">Print</button>
<script language="javascript" type="text/javascript">
function onPrint()
	var fcApplet = <%= fc.AppletElement %>;
	fcApplet.getDiagramView().print();
</script>
Could you try this with your printer? You might check if there aren't some strange margin and scale values set in the printer properties window as defaults.
bkernan
Reply #12 - Jul 16th, 2009 at 3:41pm
Thanks Stoyan, the problem is on my end, probably has something to do with my pixel units.
I dropped that code into the OrgBrowser sample and it works perfect. I'll continue to mess with my code to get it to work like this default example.
bkernan
Reply #13 - Jul 16th, 2009 at 6:08pm
Yeah my diagram was not fitting within the page like the example you provided works because my units are in pixels.
In OrgBrowser sample in the code behind I added:
d.MeasureUnit = GraphicsUnit.Pixel;
and this replicated the problem I am having printing.
using zoomToFit(); zooms the diagram in the applet in the browser, not the diagram the is printed.
I have messed around with some other setting and have not come up with a solution. I cannot set the units to 'units' instead of pixels right before I print because that would make my images and text positioning and proportions off.
Any ideas?
Reply #14 - Jul 17th, 2009 at 1:41pm
I've set the unit to Pixel and the tree was printed with the same size as on the screen. I didn't call zoomToFit - this method is intended to fit the diagram inside the view on screen, do you expect the diagram to fit on a single printed page after calling it?
