Normal Topic FlowLayout Arrange causes very long links (Read 1263 times)
tom_w
Swimlanes made our dreams
come true :-)
Oct 20th, 2008 at 5:50pm
Hi there
I'm having some problems with the FlowLayout causing very long links for no logical reason that I can understand ???
You can see this using the ProcessLayout example:
    Press Arrange.
    Delete the link between the 'Prepare Invoice' node and the 'Product Delivered?' node.
    Delete the 'Product' link between the Deliver Product and Process Payment nodes.
    Press Arrange.
    Some of the links are made very long and the diagram becomes very wide.
I'm getting this sort of thing occuring seemingly randomly in the software we are writing at present and it is worrying. Is there a reason for this and how can I stop it?
Tom
Re: FlowLayout Arrange causes very long links
Reply #1 - Oct 21st, 2008 at 1:31pm
At this time FlowLayout expects nodes to be in well defined groups, each group starting with a node whose LayoutTraits[LogicID] is set to one of the IDs in GroupStartNodes, and ending with a node whose id is in GroupEndNodes, and there should be a control-flow path from the start to end node. Deleting the links you specify breaks this condition. Now if you set the LogicID of the "Product Delivered" node to "Process Start", the method should work fine.
tom_w
come true :-)
Reply #2 - Oct 21st, 2008 at 1:44pm
Thanks Stoyo, that makes sense logically.
It would probably be neater if the user or developer had some control over what happened in this type of scenario (e.g. an AlignUnclosedGroupsLeft, HighlithgUnclosedGroups or something like that).  I can't really think of a scenario where the long links would be the desired behaviour.
