Normal Topic Re: how to save diagram using diagram.savetostring (Read 1811 times)
sarada
Oct 21st, 2008 at 6:35am
sarada wrote on Oct 21st, 2008 at 6:03am:
hi all i'm using mind fusion in my C#.net windows application.
My problem is i can save the and get back the data using
diagram.savetoxml(xmlFile); and
diagram.Loadfromxml(xmlFile);
I want the same thing to happen using savetostring but i'm not getting any diagram info so please help me out. How to save diagram in string format using diagram1.savetoxml();
and when i'm using it as
SavetoStrinFormat xmlstring=new SavetoStringFormat;
string xmldata=diagram1.savetostring(xmlstring,true);
xmldata string is empty.any solution for this
Reply #1 - Oct 21st, 2008 at 8:57am
SavetoStringFormat is an enumeration, and you should call SaveToString like this to get an XML string:
diagram.SaveToString(SavetoStringFormat.Xml);
